#3 cylinder missfirepapajimmm 05-19-2005, 10:49 AM This is actually for a 99 Plymouth Breeze (same motor as neon? and not much action on Breeze board) I have a 99 Plymouth Breeze 2.0 16v sohc, 5spd, that is showing #3 cylinder missfire; and so far I have replaced plugs, wires,coilpack and no change. The compression is pretty much the same on all 4 cylinders. I have NOT done a leakdown test yet any suggestions?? Sometimes car runs fine other times it is obviously only running on 3 cylinders. HELP?? the engine light is on and confirmed code was for #3 Cylinder miss fire, also used one of those block test kit that you put over radiator inlet and it didn't changr color indicating head gasket is good. Automotive Network, Inc., Copyright ©2012
