Manuel for a 95 SVXVH45DETTwithNOS 04-12-2002, 08:53 AM Hey which Gear box will bolt into a SVX, I need to know because well the Auto kinda gave up................... If no other can be found then I'll try my age ol' trick, Holianger... UnlimitedEK9 06-23-2004, 07:26 PM 92 Legecy UnlimitedEK9 paparicky 03-09-2008, 01:49 PM The 92-98 Subaru 5-speed gearboxes excluding Loyale and, God forbid, Justy- will bolt up to the engine. The '99 and later trannys use an 8-bolt engine mount so they will not work. You will need to fabricate the tranny mount and add a different drive shaft, as the transmissions are a different length. Just any transmission will not do, you really want the '98 WRX tranny at is it fully capable of handling 300HP. The '93-'94 Legacy Turbo tranny is also a candidate, but is not as strong. The '98 Impreza 2.5 RS might also do the job. All of these are $3500 to $4500 new. You also need to fabricate a hydraulic clutch setup and shift linkage. You also need to change the rear gear to suit the transmission (none listed use 3.54). VH45DETTwithNOS 03-10-2008, 02:07 AM cheers man, it's a old project one of 4 now.... Automotive Network, Inc., Copyright ©2012
