car shakes when braked
rober
05-16-2005, 09:33 PM
Hi,
Would someone please give me some ideas why my car shakes every time I apply brakes? Thank you.
I have a 96 Lumina, 3.1, sedan. I just replaced new front tires.
Manny_boy
05-16-2005, 10:33 PM
From your description, it sounds like parallelism. Your front brake rotors are warped, and need to be resurfaced, or replaced.
jeffcoslacker
05-17-2005, 06:32 AM
You are right, but the fact of "I just replaced the front tires" leads me to believe that the shop did not torque the lugnuts correctly. Lumina's are especially sensitve to this, esp with alloy wheels. Uneven torque will cause instant rotor distortion and "shake n' brake"
Loosen all the lugnuts, then torque them carefully to 100 ft/lbs. The problem will go away. :grinyes:
Manny_boy
05-19-2005, 02:11 PM
"shake n' brake"
you guys crack me up :lol:
paulfischer
05-20-2005, 08:58 AM
on my 99 LTZ I have a plastic bushing / sleeve/ guide (whatever you want to call it) that goes into the caliper for the mounting bolts.
They do wear out, and when worn, it will cause the car vibrate a little when braking. So I change those whenever I do a brake job.
Also had a 96 grandprix that had them. So maybe they are common on the GM cars.
jeffcoslacker
05-20-2005, 01:45 PM
It's not a bad idea to replace caliper hardware like that if it is anything but in perfect condition. Worn bushings and bent or distorted hardware or mounting bolts can really cause some strange problems.
Equally important to put Syl-Glide or some other high-temp lubricant/protectant on all moving parts and contact surfaces. After the caliper is installed, but before pumping it up to seat the pads, the caliper should slide easily and smoothly back and forth on its mounts with one hand. If not, there's something hanging.
richtazz
05-21-2005, 10:53 AM
I'd put my money on improper lug nut torque also, parts swapper monkeys don't know how to use torque wrenches.
rober
05-21-2005, 05:26 PM
Thanks all for the inputs. I replaced brake pads, and retorque the lug nuts, but the car still shakes a little when I try to slow down from 60 mph.
paulfischer
05-23-2005, 06:13 AM
Do you feel the shake in the brake pedal?
Maybe a wheel out of balance? Try replacing those plastic bushings.
