SOHC D-series Fans!!!GudeCiv 05-15-2005, 11:52 PM '90 Civic Hatch Si (Red with Wings West RS Ure. kit and Del Sol Si rims) I have a SOHC non-VTEC 1.6L setup at the moment. This is what I have and I want your opinions on my plans. I would like to make people rethink the D-Series, so all you ninjas out there just talk to me... AIM sn: DylanBrannonTKD HAVE INSTALLED Individual Throttle Bodies ($500 local shop Fabrication) 1.6L Block (SOHC ZC- the D16A6 JDM equivalent) ($300) "Gude Racing" D16Y7 Head (port+polish, springs, cam, retainers, mill, adj gear, race valve grind) (slightly used $500) Local shop Tuned Si ECU ($70) S-AFC (got from a friend $120) CIVIC EX- Fuel Rail, Adj. Fuel press. Regulator, stock injectors ($50) DC 4-2-1 Header (ebay $200 i think??) Exeddy OEM replacement clutch (ebay $100) Local Shop Overal Tuning ($400 1yr anniversary gift from my g/f Thanx Baby!!) (Everything in this first category cost ME: $2,040 i think- its late lol) HAVE BUT NOT YET INSTALLED Vortech FMU (got for $50) MSD Inline Fuel Pump ($100) 14b Turbo w/int. wastegate ($100 from nice friend, minimal shaft play) '95 CX Header (from girlfriend's long lost motor{she went with an ITR}) 310cc RC Injectors (slightly used $250) 1st Gen. Eclipse Stock BOV (complimentary with turbo purchase) ACT 12lb Flywheel (free from a buddy 'kuz his motor died) Urethane Motor Mounts (free from the same buddy) (Everything in this second category cost me: $500) WANT OR NEED LIST Intake Turbo Charge Piping and Intercooler 24x7x3 ($800) Custom Plenum on ITBs to make turbo compatible ($200) Stage 1 Block Sleeving ($900 labor included...good for 20psi) T25 Ball bearing w/higher quality header ($800/$150) ARP studs ($130) Boost Controller ($???) Stage??? Stronger Clutch ($300) Rod and Pistons "Eagle" (ebay$650??) 15" Rota Slipstreams ($400) Falken Azenis to fit Rotas ($400???) PLEASE CONTACT ME IF YOU HAVE ANYTHING I MAY NEED OR WANT OR ANY INFO YOU CAN SHARE WITH ME PLEASE scottsee 05-16-2005, 11:03 AM aeromotive for the afpr. manual boost controler for $10-60 that fmic is way to big for the 14b new exhaust manny with 6mm dsm flange pocketlogger 190+ walbro fuel pump or eqivulant colder plugs, hotter spark coil/ignition system civickiller 05-16-2005, 04:54 PM also one important question, is how much power do you want to make ? you aint gonna make people rethink the d series unless your throwing down 500whp GudeCiv 05-16-2005, 09:11 PM I understand a 14b is dinky but will spool up when i need it when I go autcrossing. The intercooler is not specifically for the 14b, as in the 14b is a temp fix so I can start building it. Also a streetable 200whp from the 14b is a temp goal. I guess if I'm going to upgrade to a T-series I have been thinking about the T3/T4 if I want Drag purpose power. Obviously its a Honda and I'm not rich, so 500, well it would be tough wouldn't u say, but who in this class has a DOHC at 500hp??? If i wanted raw horsepower in a d-series, it is a waste of money in my case. I do not mean this set up for drag, where 500 horse would hinder an autoX event- would it not? Esp in a civic like mine. Very unusable and unnecessary horse. I dont mean for the d-series to be more powerful than any b-series. My purpose is to make people rethink the D-series, in a unique agile and responsive setup. I guess you could say I want 200-300whp in this unque setup, striving for response and reliability. I guess I should reword my purpose, Shed a new light on the d-series stereotype. thank you. GudeCiv 05-16-2005, 09:19 PM Hey, I'm sorry...that message I just wrote sounds a little offensive, please do not take it that way, I appreciate everyones response, I just like to express myself. And about the intercooler, should I save money and run without one until I get a diff turbo set up or should I just 14b it for a while? civickiller 05-17-2005, 03:17 AM if you want it bad enough, you can get it. if you want it for autoxing then a smaller turbo is good so it spools early scottsee 05-17-2005, 11:01 AM if your poor then 500hp is nowhere in your future. 200-300whp is easly do able on a 14b! the 14b has propeled 1g dsm's into the 11's. Turbos are strait forward. they have flowcharts to show you what to lb/min air flow at certin psi's. the most important thing about a trubo setup is supporting the turbos effency range. a 14b is probably the best budget turbo i know of. autocross, drag, street, its a great 30/lb min turbo and can be had for $100 relitivly easly online. there is no way i would ever run a 14b or any other turbo without an intercoler. if your only going to be running 10-15lb boost i would suggest a supra sidemount, or rre sidemount. you could add a $120 water injection into the throddle elbow to help detination and reduce tb/intake/charded air temps. water injection is a bad ass tool!! you can really spend as much as you want to on parts. but with a little reading, resarching, looking you can get into the 12's with a 14b/vtec setup for around 2 grand. Automotive Network, Inc., Copyright ©2012
