Originally Posted by Silverbolt
S.O.S. which translates to Same 'Ol Shyat
The ebay guys are all getting their stuff from the same place all the other dealers are. Its cheaper on Ebay because those ebay guys dont have to pay for overhead, or website hosting for their online stores. They pass their savings on the the ebay buyers. Also, when you buy from ebay, or anywhere else for that matter. Do a little research into the specific type of headlight it is... which manufacturer/brand name, and whats their reputation?
If you get Denji, dont run with your highbeams on all the time. Only use them when you HAVE to use them. Otherwise, they'll burn through the halo/angel eye's wiring and short them out.
I think thats the case with most Halo's. I know Sonar and their many offshoot names (Gen 3 is an example of a Sonar brand, among others) does this too, fairly quick. Also, I've noitced that when people have someone install their halos, the installer use a tap to tap into the parking light wiring to power them versus cutting and splicing them in, then crimping the connection with crimpers, whihc is more soild. I have seem this type of install result in dead halos more than once after awhile, becuase the taps just, wel, arn't very solid. More than once I've had to fix halo wiring does that way.
I can varify using the high beams like they are ment to be used, only when you NEED THEM, will help overt any issues which may or may not have arised otherwise. I've had my Denji's for around 4 years now, and they work fine...the low beams, high beams, and Angel Eyes (I still perfer to call eHalos buy the older "Angel Eye" name, LOL). Now my first set of angel eye projectors wans't Denji, and that was a different story.
I had a pair of Halos before this pair, when they first came out ages ago. Innotive Performance was the brand, called the halos "Eagle Eyes." At any rate, I used the high beams for awhile the first day, maybe a half hour total...the low beams fried within the first 12 hours..never worked again. Something shorted out on the inside, crappy wiring. Wiring has gotten better with halo's snce the first pair where made. They still can have issues, but the wiring is better than it used to be.
At any rate, I can varify that using the High beams
