Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 05-15-2005, 11:12 AM   #1
jblack523
jblack523 Normal reputation
Question 95 c1500 check gages light trans shift problem
My check gages light flickers, and the tachometer and speedometer are not working. When this happens, it does not shift properly. Seems like I only have 2nd and 3rd gear. Was an intermittent problem until recently. Have replaced battery cable, cleaned posts, etc. Any advice would be greatly appreciated.
jblack523 is offline   Reply With Quote
Old 05-16-2005, 01:09 AM   #2
2000CAYukon
2000CAYukon Normal reputation
Re: 95 c1500 check gages light
A flickering light can be a misfire. You should still scan for codes to see any are stored.
A misfire can be many things but a good place to start is with cap and rotor, wires and plugs.
You can also search for misfire in this section and find many posts on the subject.
//2000CAYukon
2000CAYukon is offline   Reply With Quote
Old 05-16-2005, 02:11 PM   #3
mbumgua
mbumgua's Avatar
mbumgua Normal reputation
Bad ignition switch can cuse some problems like this--worth taking a look at. Try turning ignition key a fraction more towards the off position, but not off, and see if that changes anything.
mbumgua is offline   Reply With Quote
Old 05-18-2005, 09:49 PM   #4
jblack523
still having problems
I've replaced plugs, wires, rotor, distributor cap. Tach and speedometer still not working. Could transmission be in "safe mode"? Thanks
Old 05-18-2005, 10:18 PM   #5
2000CAYukon
Are there any codes stored?
//2000CAYukon
Old 05-22-2005, 11:49 AM   #6
jblack523
Ignition Switch
Replacing ignition switch cured the problem. Thanks for all assistance
Old 05-22-2005, 08:21 PM   #7
mbumgua
mbumgua's Avatar
Glad you got it fixed--but it is a strange part to cause those problems!!
Bookmarks
Google
Web AF
