odd idle
Quetzolcotl
04-11-2002, 08:49 PM
after my car has warmed up the idle fluxuates. it will rev up 2-300 rpm and go back to normal over and over again. as soon as it returns to normal it goes up 2-300 then back down and then up, and back down, ect. the needle never stops moving. the battery and alternator are fine as well as well as the vacuum hoses. what could be causing this?
pvang31019
04-11-2002, 11:35 PM
it's a vacuum leak. Have you sprayed the lines down with carbcleaner to check for leaks? Used a vaccum pressure tester? Check your intake manifold & throttle body gaskets?
Quetzolcotl
04-11-2002, 11:55 PM
i got to get a moderator to delete some of these threads, its on here 5 times. my damn computer kept not doing anything so i didnt think it worked.
si00000
04-12-2002, 12:17 AM
I believe that it is a vaccum leak also.
civicx_xracer
04-12-2002, 12:56 AM
If it's not a vacuum leak try this...mine was doing that and I needed a new battery. I think the ecu was trying to compensate for not enough power to it. If you battery is fine then it is probably your egr valve. Let me know if those don't work
Quetzolcotl
04-12-2002, 02:19 AM
just got a new battery yesturday. i'll check for vacuum leaks. i just got a new engine put in so maybe something is loose. thanks
