92 Dakota.signals Wont Blink-flasher Ok.JAYEXPORT 05-13-2005, 02:59 PM 92 Dakota. Signals Won't Flash. Lights Come On. Flasher Ok When Signal Placed On Postion, Brake Light Goes Out. Same For Both Sides. No Tail Lights Now Either. Started Out On Passenger Side. Then Moved To Driver Side And Now No Tailights. Help With Ideas , Please. rksnc 05-13-2005, 05:00 PM Sounds like bad grounds for the lights. Need to start where first problems started and work from there. The ground could be bad in blub housing, wiring. I would start at the light socket first. JAYEXPORT 05-17-2005, 09:37 AM Sounds like bad grounds for the lights. Need to start where first problems started and work from there. The ground could be bad in blub housing, wiring. I would start at the light socket first. THANK YOU VERY MUCH FOR YOUR HELP. I WILL TRY THAT!!! JAY Automotive Network, Inc., Copyright ©2012
