Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 05-10-2005, 06:42 PM   #1
airtight_python
airtight_python Normal reputation
Cluster LEDs
Does anyone know what kind of LEDs those are in the instrument cluster? Size, voltage, mounting?
airtight_python is offline   Reply With Quote
Old 05-13-2005, 11:26 PM   #2
sportin83
sportin83 Normal reputation
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i would like to know too?
sportin83 is offline   Reply With Quote
Old 05-14-2005, 01:34 AM   #3
airtight_python
Re: Cluster LEDs
Think I figured this one out sportin... You'll need 6 twistlocks and 6 #194 LEDs with the 4 separate little bulbs on them (these give it just the right brightness). Just twist the LEDs into the twistlocks. Then twist the old ones out of the cluster and reinstall these new twistlock/LED combos. Test if all the LEDs work before buttoning everything up. If one doesn't work turn the bulb 180 degrees in the twistlock. Warning that there might be "hotspots" or places that are brighter right where the bulbs are under the cluster. Use some little pieces of the rubber bulb covers or something right on the tops of the bulb to dim the bulb right there and prevent the hotspots. Note that the dimming feature also will not work with LEDs, simply on and off. You can get both of the things from ebay. The LEDs might be a couple bucks each and the twistlocks are like .59 cents. If you want to change the other little bulbs at the top of the cluster like the highbeam indicator those are a smaller LED... I believe its T1.5 or something.. they already have the twistlocks on them.
Bookmarks
Google
Web AF
