Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 05-09-2005, 05:38 PM   #1
mushhhy
mushhhy Normal reputation
97 Ignition Switch Replacement
Can anyone explain to me how to find and re[place the ignition switch in a 97 balzer
mushhhy is offline   Reply With Quote
Old 05-09-2005, 05:51 PM   #2
Rick Norwood
Rick Norwood's Avatar
Rick Norwood Normal reputation
Re: 97 Ignition Switch Replacement
Have you tried a search for ignition switch on this forum? It has been covered many times.
Rick Norwood is offline   Reply With Quote
Old 05-09-2005, 05:52 PM   #3
mushhhy
Yes I have and am currently in the process can you give me a hand this thing is driving me nuts and it will be dark soon I would like to get it done b4 then
Old 05-09-2005, 06:00 PM   #4
mushhhy
Just found what I think I need.
Did you ever get help with your question? If not, I had the same situation with my 97 Blazer and I replaced the ignition switch to fix it. It's not to difficult to do.
Remove the lower dashboard, remove the two nuts that hold the steering column up, & remove the plastic shell around the switch area. I had to buy a special tool to actually remove the switch -- it was basically an inverted "star" socket.
The wires from the switch run along the steering column down to the firewall, where the wire casing is bolted into place.
I will let you know how it works.
Thank you
Old 05-10-2005, 06:28 AM   #5
mushhhy
Can anyone explain how to remove the Ignition switch? I have removed the lower dashboard and the covers over the steering column. I cannot get the switch off. there is what appears a bolt with an inverted stars head on it it is smaller than the smallest in my set where may one be purchased? I went to sears and Autozone did'nt have it am going to try another auto perts store today. Does anyone think this might be the Ignition switch that is causing these problems? I am getting a code PO300, and PO141. random misfire and 02 sensor bank one (I believe).
I am not getting much response so I do not know if these questions are nonsensical or that it may be that noone cares tohelp me out. this thing has driven me into the ground financially I have over $3,500 in it with the new engine and all the parts and labor at the Mechanics. I wish I could get some direction to help me get this problem solved.
Old 05-10-2005, 10:08 PM   #6
CrooK CA13
CrooK CA13's Avatar
CrooK CA13 Normal reputation
Send a message via Yahoo to CrooK CA13
yes replace switch..i had 6 different problem codes that related to my transmission....did research on here and found ign switch was the problem ..so i took the chance...and now no more engine light or funny running blazer....120 bucks isnt to bad...i also installed it myself...some of those bolts ...just have to use some physical persuasion....know what i mean
CrooK CA13 is offline   Reply With Quote
Old 05-11-2005, 06:25 AM   #7
mushhhy
Thanks,
Where I am now is, I ran it yesterday to get what I think or thought was bad gas out of the tank. I filled it back up and put some sea foam fuel additivein the tank and it ran fine. The codes went out after a few miles. I let it sit a few hours and took it for another spin and it ran great again for about 15 miles then it just died. it sounds like it wants to turn over but when it does start it will only run very rough then die. where do you think I should look? Still yhink it is the ginition switch? I fso does anyone know what size the inverted starz bit is in the steering column it is smaller than the smallest in my set which is an E-6. I have the time an desire to get this fixed tody help please
Old 05-11-2005, 06:44 AM   #8
mike2004tct
mike2004tct's Avatar
mike2004tct Normal reputation
Re: Re: 97 Ignition Switch Replacement
Thanks,
Check out this post from last year originally posted by Sfrid073 and CCCD;
http://www.automotiveforums.com/vbul...CH+REPLACEMENT
mike2004tct is offline   Reply With Quote
Old 05-11-2005, 07:17 AM   #9
mushhhy
Thanks Mike2004tct will do NOW
Old 05-11-2005, 11:53 AM   #10
mushhhy
Well I just replaced the Ignition switch (not the problem) it wants to turn over and does, just before starting it dies. Any suggestions?
Old 05-11-2005, 12:04 PM   #11
Rick Norwood
So you're basically saying it won't start, or that that the starter quits turning?
If it simply keeps grinding away but doesn't start, I'd suspect the ignition module inside the distributor. It is easily removed and can be tested off of the vehicle at Autozone.
Old 05-11-2005, 01:04 PM   #12
mushhhy
No it will not start.
It will turn over and begin to start then chug a few seconds then die. Fuel filter, pump, and pressure are fine. Still think it is the module?
Old 05-11-2005, 01:33 PM   #13
Rick Norwood
I might be the ignition module. I had the same thing happen to my 93 last week. It would start and run until it almost reached normal temp, then would die. I replaced the ignition module and all was good again.
Most mechanics/parts stores will tell you that ignition modules are either good or bad. The truck will run or it won't start, and are rarely intermittent. But I have seen it both ways. If you live near an Autozone, call and ask if they have the ability to test your ignition module off of the truck. If so, they'll do it for free and free works. If it is not the ignition module, you can rule it out.
Old 05-12-2005, 08:20 AM   #14
mushhhy
I am tired of this piece of s**tand my lack of knopwledge. I sent the Blazer to a real mechanic. I do not want to mess with anything else and screw it up worse than it is. I wioll let ya know what happens.
Old 05-12-2005, 08:27 AM   #15
Rick Norwood
Hey Bro, Don't be discouraged. We've all had a vehicle that we've pulled our hair out with. If you succesfully R&R'd the ignition switch, you've tackled a job that most won't do.
The trick is to now peek over your mechanic's shoulder if he'll let you, and learn a little bit more.
None of us hard working Stiffs can afford all of the high tech equipment to properly analyze and repair today's vehicles. Once you get the ol' dog running again, keep a good maintenance schedule and it should serve you well for years to come.
Rick
Bookmarks
Google
Web AF
