Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > F Series
Old 05-08-2005, 11:30 PM   #1
pippin_s@mchsi.com
pippin_s@mchsi.com Normal reputation
Question 2001 F-150 Skipping
I have a 2001 F150 SuperCrew that is skipping periodically when the engine is put under a slight strain. The engine light will not come on to tell me what the problem is. I had it in the garage and had the transmission serviced, fuel filter changed, etc but they told me they couldn't determine the problem until the engine light came on. I have also changed 6 of the 8 spark plugs (the last two on the back of the driver's side are nearly impossible to get to). The plugs I replaced look okay. Of course this engine doesn't have plug wires so changing them isn't an option. Note: Engine is the short block V8. I'm at wits end...someone please help!
pippin_s@mchsi.com is offline   Reply With Quote
Old 05-09-2005, 08:28 AM   #2
way2old
TOKEN HILLBILLY
way2old's Avatar
way2old Normal reputation
Re: 2001 F-150 Skipping
Replace the other 2 plugs. Also look closely at the coil boots to see if there is any sign of arcing, usually a small white spot. Or to see if the bottom of any boots are cracked.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Old 05-10-2005, 09:10 PM   #3
jeffroski
jeffroski Normal reputation
Angry
Make sure to change those plugs cold, otherwise you'll possibly have one blow out. the first sign is an exhaust leak sound, such as a mild ticking. Number four was the one that let loose on me, only a $1500 repair job.
jeffroski is offline   Reply With Quote
Bookmarks
Google
Web AF
