help me find a st205 hoodtEaM_oMeGa 05-08-2005, 03:09 PM Does any one know where i can buy a st205 hood? I might need it for my WRC engine cause i think the factory 94 celica gt hood wont close after I'm done with the swap. At least that's what i've heard. Any advise or ideas, please post. blakscorpion21 05-08-2005, 03:14 PM are u doin a 6th gen 3sgte swap? tEaM_oMeGa 05-08-2005, 03:46 PM are u doin a 6th gen 3sgte swap? this is a 94 celica gt with a 2 gen 3sgte WRC swap. any suggestions? blakscorpion21 05-08-2005, 10:41 PM oh i thought u were doing a 3rd gen 3sgte in a 6th gen celica. i was just curious cause ive never heard of anyone doing that swap. nialusa 05-09-2005, 05:40 AM You`ll need to buy the nose cone aswell as the bonnet has a rise in the middle which isnt covered by the non gt4 nose cone. Whats a 2nd gen 3stge wrc? do you mean the RC or CS? tEaM_oMeGa 05-09-2005, 09:19 PM You`ll need to buy the nose cone aswell as the bonnet has a rise in the middle which isnt covered by the non gt4 nose cone. Whats a 2nd gen 3stge wrc? do you mean the RC or CS? yeah. my fault, i meant the 2nd gen 3sgte RC motor. but anyways, where would i find the nose cone and the bonnet? nialusa 05-10-2005, 12:50 PM AToyota dealers would be the most obvious place to start, but probably the most expensive, try looking for a japanese/australian or european scrap dealers that will post you one out. The part numbers for everything necessary are below. Bumper Parts Cover, front bumper 52521-20200 $223.27 This is the bumper Absorber, front bumper energy 52611-20150 $62.76 This is the foam that goes behind the bumper Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place Grill, sub-assy, rad., center 53101-20500 $46.29 This is the upper grille Grill, radiator, lower 53111-20750 $125.08 This is the lower grille Bezel, grille, lower RH 53112-20240 This is the right-hand bezel for the lower grill without fogs Bezel, grille lower LH 53113-20180 This is the left-hand bezel for lower grill without fogs Front turn signal, RH 81510-20750 Front turn signal, LH 81520-20750 Fog Lights and other Optional Parts Fog lamp, RH 81210-20370 Fog lamp, LH 81220-20360 Bezel, grill lower RH 53112-20230 This is the right-hand fog light bezel Bezel, grill lower LH 53113-20180 This is the left-hand fog light bezel Latch, hood, LHD 53510-20510 This is the left-hand-drive GT-Four hood latch, without it, you'll have to lengthen your stock latch by about 1/2 inch. Bracket, upper grill #1 53115-20070 $13.95 This is 1 of 2 brackets which hold in the upper grill Bracket, upper grill #2 53118-20070 $15.46 This is the 2nd bracket for the upper grill You can also get the reinforcment bar(your "crash-bar" or 5MPH bumper) and frame brackets, but theyre not nessicary, and the frame brackets required to use them are $180 EA from toyota. so just about everyone dont get it, they just cut down theyre crash bar with a sawzall. Hood Parts Hood sub-assy. 53301-20500 $444.22 This is the hood Plate assembly, hood bulge 76190-20010 $ 42.95 This is the middle hood vent Bulge assembly, hood 76180-20010-XX This is the hood bulge. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes. 76180-20010-F0 576, Super Bright Yellow 76180-20010-H0 752, Deep Teal Metalic 76180-20010-H1 753, Graish Turquoise M.M. 76180-20010-B0 183, Dk. Bl. Gray Me 76180-20010-G0 6M1, Dk Green Mica 76180-20010-G1 6R0, Lt Green Me. 76180-20010-A0 040, Super White 2 76180-20010-B0 199, Silver Me. 76180-20010-C0 202, Black 76180-20010-D0 3L2, Super Red 76180-20010-J0 8L5, Blue M.M. (perfect Blue) Ornament sub assy, hood RH 75033-20030-XX This is the right-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes. 75033-20030-F0 576, Super Bright Yellow 75033-20030-H0 752, Deep Teal Metalic 75033-20030-H1 753, Graish Turquoise M.M. 75033-20030-B0 183, Dk. Bl. Gray Me 75033-20030-G0 6M1, Dk Green Mica 75033-20030-G1 6R0, Lt Green Me. 75033-20030-A0 040, Super White 2 75033-20030-B0 199, Silver Me. 75033-20030-C0 202, Black 75033-20030-D0 3L2, Super Red 75033-20030-J0 8L5, Blue M.M. (perfect Blue) Ornament sub-assy, hood LH 75034-20030-XX This is the left-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes. 75034-20030-F0 576, Super Bright Yellow 75034-20030-H0 752, Deep Teal Metalic 75034-20030-H1 753, Graish Turquoise M.M. 75034-20030-B0 183, Dk. Bl. Gray Me 75034-20030-G0 6M1, Dk Green Mica 75034-20030-G1 6R0, Lt Green Me. 75034-20030-A0 040, Super White 2 75034-20030-B0 199, Silver Me. 75034-20030-C0 202, Black 75034-20030-D0 3L2, Super Red 75034-20030-J0 8L5, Blue M.M. (perfect Blue) Guide,air to cowl 76191-20901 This if the optional hood spoiler Try this place -http://www.toyotaworld.com/ or this place www.toysport.com tEaM_oMeGa 05-10-2005, 08:30 PM Thanks for your help guys. celiracer94 12-06-2005, 01:21 PM I don't think that you need the hood your stock one should work there are many cars using it. also check out www.6gc.net thats usually where I am on -Dans_st blakscorpion21 12-06-2005, 04:04 PM I don't think that you need the hood your stock one should work there are many cars using it. also check out www.6gc.net thats usually where I am on -Dans_st dude, dont bring back old threads. this guy prolly already has the hood. jaybratt 12-08-2005, 04:09 AM Why can old threads never be deleted? is that a bad idea or something? Or at least closed to where you can't post in them anymore. Maybe a MODERATOR should read this and suggest it to someone who has the power to affect the site. calicelica 12-08-2005, 03:59 PM only for reference, so its there when you use the search box...although this is so random. But I've never seen such a pretty close up pic of a wrc st205! But still, st105 has more outdoor look. Automotive Network, Inc., Copyright ©2012
