Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 05-07-2005, 11:57 PM   #1
chevyman02
chevyman02 Normal reputation
Removal of door panels
Hello I have a question about my 2004 Chevy Silverado LS 1500 door panels. Can anyone tell me how to safely remove the door panels without breaking things. I have located one single bolt head under the door handle. Is this the only bolt that I must remove and is the rest of the door held in with the little plastic clips. Thanks chevyman02
chevyman02 is offline   Reply With Quote
Old 05-08-2005, 01:55 AM   #2
airtight_python
airtight_python Normal reputation
Re: Removal of door panels
In 2002 models there is that screw under the armrest/handle, one on the bottom of the panel and for the final one you must remove that plastic piece from around the handle which you use to open the door. The final one is under there. Remove the piece where the mirror is and then lift up. It is held on with L brackets. Be sure to pop up and disconnect any electrical switches you have on the panels. Everything clips or snaps in. If you have trouble use a screwdriver but be careful as not to scratch things...
airtight_python is offline   Reply With Quote
Old 05-09-2005, 10:09 AM   #3
jeverett
jeverett's Avatar
jeverett Normal reputation
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
There are bolts under the door handle, one under the bottom of the storage pocket, and another behind the window/lock switches. You must pop that pod out witht he swtiches to access the screw. Un do the 3 screws, and pull the panel UP NOT OUT..
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
jeverett is offline   Reply With Quote
Old 05-09-2005, 01:04 PM   #4
airtight_python
Re: Re: Removal of door panels
I dont have the window switch panel because I have a cheap model with only power locks. That's messed up how they make them different. Eventually I will upgrade to power windows and mirrors and just swap out the door panels. I even thought about changing the interior color. I have the charcoal but I like the light gray much better.
Old 05-09-2005, 01:47 PM   #5
jeverett
jeverett's Avatar
weird..power locks and manual windows?? I've never seen that before
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-09-2005, 03:34 PM   #6
99redsilverado
99redsilverado's Avatar
99redsilverado Normal reputation
thats my setup too, its ok but itd be a lot better with power windows too.
'99 Silverado 4 x 4
bunch of goodies
99redsilverado is offline   Reply With Quote
Old 05-09-2005, 03:50 PM   #7
BlenderWizard
BlenderWizard's Avatar
BlenderWizard Normal reputation
Send a message via AIM to BlenderWizard
Alight since we're talking about power windows, why does the switch "lock" in the down position, but not in the up position? No car that I've owned did, and I just think it's silly they don't add that.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
BlenderWizard is offline   Reply With Quote
Old 05-14-2005, 09:41 AM   #8
ctimmons
ctimmons Normal reputation
Simple: Safety. Some dumb S%%T hanging his head out the window, up it comes. Scrunch. Thats why they changed the buttons so you have to pull them instead of push to raise the windows. Dogs stick head out window. Step on switch. Rest is history.
ctimmons is offline   Reply With Quote
Old 05-14-2005, 09:58 AM   #9
BlenderWizard
Re: Re: Re: Removal of door panels
Someone ought to make an aftermarket switch that has this feature for those of us who are not dumbasses. I mean, I'm not going to roll my own head up in the window.
Old 05-14-2005, 11:58 AM   #10
jethro_3
jethro_3's Avatar
jethro_3 Normal reputation
My brothers Beamer has a pressure sensative window that will lock in the up position and when it senses resistance it will go back down not just stop. Remember we are in the world of I am too stupid to think or be responsible for myself, thus we need more stupid lawsuits. I do not consider myself in the stupid is as stupid does group.
jethro_3 is offline   Reply With Quote
Bookmarks
Google
Web AF
