Check Engine Light With The Turbo
IMPORTMUSCLE
05-06-2005, 04:53 PM
My Car Will Not Pass Smog Because Of The Light. What Can I Do To Allow The Sensor To Continue To Work But Allowing Higher Than Stock Specifications? New Ecu? Rewire? What Manual? Please Help?
Jim
Greenblurr93
05-06-2005, 06:30 PM
have you upgraded your MAP sensor??? if not, when it reads boost over 10psi, it will throw a CEL.
IMPORTMUSCLE
05-06-2005, 07:23 PM
Yes, I Went And Bought The Missing Link. It Was Good For About A Few Days But...nothing Happened
Greenblurr93
05-06-2005, 07:36 PM
get a o2 simulator, your o2 sensors may be reading more exhaust coming out than normal and throwing a code.
IMPORTMUSCLE
05-06-2005, 07:50 PM
Great Thanks For The Help!
Do You Know Any Companies That Manufacture Such A Thing. And What May Be A Good One.
Jim
superbluecivicsi
05-06-2005, 08:18 PM
pulling that code is your answer ;)
shakes
05-06-2005, 08:39 PM
Jim
no doubt. what code is it throwing, what car, engine, turbo other upgrades.
Skyline_BNR34
05-06-2005, 09:07 PM
To get the O2 sensors is to go to a regular parts store and they will have them... Good luck at the problem..
Greenblurr93
05-06-2005, 09:20 PM
no im talking about a O2 SIMULATOR... it make the ECU think everything is ok so you dont throw a code.
www.02simulator.com (http://www.02simulator.com)
IMPORTMUSCLE
05-06-2005, 09:25 PM
2000 Honda Civic Ex
Garret Turbo T3/t4
Intercooler
420cc Injectors
Aem Fuel Rail
Accel Cables
Tanabae Cat Back 3in
Chip
Missing Link
......etc
IMPORTMUSCLE
05-06-2005, 09:28 PM
Fuel Pump Upto 60lbs But It Has A Regulator, So Realistically It Will Never Get To That But If Needed.
superbluecivicsi
05-06-2005, 10:56 PM
CivicSpoon
05-07-2005, 03:51 PM
:1: If you want help, you're going to have to do a lot better. There are a ton of codes you could be throwing and a ton of different reasons you could be throwing them. You're the one with the car (which you haven't even said what car you have), so if you want help then tell us what code you're throwing.
97integrals
05-07-2005, 05:43 PM
:werd:
IMPORTMUSCLE
05-09-2005, 12:05 PM
I Told You What Kind Car It Was If You Looked Above Bud. But If You Are Going To Be Sarcastic I Can Just Get An Expert To Look At It.
CivicSpoon
05-09-2005, 12:12 PM
You're right I did miss that, it is above, but you still didn't say what codes you're throwing (which is important for anyone to help you).
h22meangreen
06-04-2005, 06:03 AM
i dont think he understands that he can read the code and see whats wrong with it. it could just be a bad sensor. anyways, somebody tell this dude about reading trouble code im going to sleep
