Just about to buy my first 6ejenner 05-05-2005, 04:58 PM Hi all, New to this board so not sure how popular it is and if anyone will read or reply... here goes. I'm just looking at a 1989 635 highline. It's done 60,000 miles which seems quite low for a car of this age. It has a comprehensive service history and lots of paperwork. I like the car and have a holding deposit on it but I would like to ask a couple of questions: - Is it normal to see some oil seepage on these cars? I was allowed to look underneath and I can see some oil leaking from seal at the gearbox output where it joins the prop shaft, more from the join between the g/box and engine (where the torque converter is) and some from the front of the engine (possibly cam-shaft or chain tensioner gaskets?) The leaks look small and slow - so is this normal? - two BMW dealers said it's not unusual to see a bit of seepage and as an owner, driver and rebuilder of 79'-93' Saab 900's I'm used to seeing a bit of oil leaking at joins. I just don't know the 6 well enough to be sure. - second question - are there any other tips prior to potential 6 ownership? There does not appear to be any rust anywhere (inc. front wings) the engine mounts all look sound, the rear dif is dry-as-a-bone - no leaks there... only other problem I noticed was that the heat-shields above the exhaust manifold have worn through on the top side and probably should be replaced. Thanks for any advice. Regards, Emmett. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
