Audi 90 engine swapbeastfromeast 04-09-2002, 09:01 AM is it possible to put a S4 or S6 engine in an Audi 90 '93? Peace y'all, Raph... Sadiztik 06-11-2002, 04:35 PM anything is possible I though you may lose most of your luxuries and it will cost a shitoad of money CK_S4 07-28-2002, 09:47 AM The swap is entirely possible. It wont' work as well in the 93-95 models as well as it would in a pre-91 model however. The 93 uses a 12V V6 which is found also in the Audi 100. Different engines mounts/suspension etc. The best swap would be a 91 or older and put a 20V Turbo 5 from a 200q or an early S4. It's actually not that expensive either provided you find the engine. Another common swap is the turbo 10V 5 from a 5000CS/200 into a 4000. I have also seen 20V turbos put into coupe quattros. webcrawler 10-27-2002, 06:01 AM The S4 Engine - 20v 5 valve comes standard in: 1990-1991 - Audi 90 Quattro / Audi Coupe Quattro Audi Ryder 09-11-2003, 11:36 PM is it possible to put a S4 or S6 engine in an Audi 90 '93? Peace y'all, Raph... Specify what year S4/S6 engine you would like to swap. Do you think you would want to do this conversion? conversion specialists (http://www.boykinracing.us/index4.htm) beastfromeast 09-19-2003, 08:26 PM Tks guys but the project is off now, we bought a brand new S4 Peace y'all... Audi Ryder 11-01-2003, 09:46 PM The S4 Engine - 20v 5 valve comes standard in: 1990-1991 - Audi 90 Quattro / Audi Coupe Quattro Not so. The UrS4/S6 engine is a 2.2L 20v 5cyl turbo (AAN engine code). The motor in the Audi 90 and Coupe Quattro is a 7A code non-turbo motor. The '91 Audi 200 came with a early variant of the UrS4/S6 engine, known as the 3b. They are a little cheaper, but hard to find nevertheless. shameless plug (http://boykinracing.us/index2.htm) Automotive Network, Inc., Copyright ©2012
