Finding gear ratio?BoogerBomb 05-04-2005, 05:03 PM Imlooking for a new front diff for my 90 S15 Jimmy 4WD and was wondering how can you find out the gear ratio if there are no visible markings on either the front or rear differential? BoogerBomb 05-04-2005, 05:14 PM nebermind I found out that its one of the slew of 3 digit codes in the glove box. Its GU4 3.08 blazee 05-04-2005, 05:17 PM Look in your glove box, there is a sticker with a bunch of codes. Those are RPO codes, they tell everything that was put on your blazer. You will see one that says GU followed by a number. Tell me the number and I'll tell you the ratio. The most common is GU6 which is 3.42. blazee 05-04-2005, 05:19 PM nebermind you found it. :lol: BoogerBomb 05-04-2005, 05:40 PM Whis is better 3.08 or 3.49? Whats the difference between the 2 besides 0.41? blazee 05-04-2005, 05:46 PM 3.49 or 3.42? 3.08 will give you a higher topspeed and a little better fuel economy. The other will give you better bottom end torque. If you change the ratio of the front you have to change the back to match. Automotive Network, Inc., Copyright ©2012
