wanted and looking for keyless entry program for sebring 2001
sierra305
05-03-2005, 10:03 PM
iam looking for the way to program the keyless entry for my 2001 sebring ..
bearcatdon
05-10-2005, 05:47 PM
This may work.
FOB programming for a 2003 Sebring convertible
(may also work for cars with p/n 04602260 AA, FCC ID GQ43VT17T)
1) Turn ignition switch to the ON/RUN position
2) Using a currently programmed transmitter, press the Unlock button. Continue holding the Unlock button for 4-10 seconds, then press and hold the Panic button for at least 1 second. Release both buttons simultaneously. You will hear a chime to signal that you can proceed with programming the new transmitter.
3) Press and release the Lock and Unlock buttons simultaneously, followed by a press and release of ANY button on each new transmitter to be programmed as well as the original transmitter. You will hear a chime when a transmitter has been successfully programmed. You will have 30 seconds to finish programming all new transmitters. A chime will sound when the 30 seconds is over or the ignition switch is turned to the LOCK position.
SebringYves
05-16-2005, 04:33 PM
look at http://autorepair.about.com/library/illustrations/bl206a-lib.htm
