Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 05-03-2005, 04:02 PM   #1
ringsincorona
ringsincorona Normal reputation
Send a message via AIM to ringsincorona
hesitation problems
I just recently had my fuel system cleaned out, filter replaced, and replaced the plugs and wires (Ive heard you shouldnt do this) and my car is still hesitating when I come off an idle. It runs almost perfect from a cold start. I saw another thread by a guy that had an older z24 and it was the same exact thing, he had to reprogram something in the car to get the cylinders firing right and the fuel flowing normal. I also just recently got 2 codes, O2 sensor (plug wires?) and heater circuit(?).
If it is the plug wires, where can I get OEM or atleast some that will work correctly? Thanks.
ringsincorona is offline   Reply With Quote
Old 05-03-2005, 06:24 PM   #2
jayson716
jayson716 Normal reputation
Re: hesitation problems
02 sensor is not plug wires. and it will cause a problem with the fuel air mix.... it is located on your exhaust
-Jay Jones
Team DROPZONE
Vice President
jayson716 is offline   Reply With Quote
Old 05-03-2005, 07:40 PM   #3
ringsincorona
no i read that bad plug wires lead to false codes being thrown...and i heard there was two on the 2000 cavalier...one in the exhaust manifold and another behind the cat, but I keep hearing different things, and the
only way to fix the o2 sensor is to buy another one correct? there isnt a fix like the tcc solenoid thing or whatever? how would i know if that problem occured? if i can remember when i got the code read it was like P104 or something.
its very important i get this fixed as i live in winterpark, fl and drive to work everyday to the int'l airport, which is close to an hour away.
Old 05-04-2005, 09:39 AM   #4
ringsincorona
anybody?
Old 05-04-2005, 10:42 AM   #5
OverAllComa
OverAllComa Normal reputation
Send a message via AIM to OverAllComa
A Bad O2 sensor code means you have bad O2 sensor. Replace them both, its nothing but a few turns of a ratchet. And if you ever "fix" the TCC Solenoid by unplugging, you don't need to be working on cars, ever.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
OverAllComa is offline   Reply With Quote
Old 05-04-2005, 12:18 PM   #6
ringsincorona
Not exactly what I was talking about - what I meant by fix was to "remedy" the problem "temporarily". But I understand the internet is your place to act like a hard ass.
As to the other person who actually gave me some insight without acting like a fool, thank you. I'll go about my way and replace the O2 sensors and hope it solves my problem since that question wasn't really answered.
Old 05-04-2005, 02:13 PM   #7
yautja25
yautja25 Normal reputation
ok wat else would b the problem of accleration hestitation and knocking of something under hood if u changed wires and plugs and didnt fix could it b a coil pack doin the knockin and crap
yautja25 is offline   Reply With Quote
Old 11-12-2005, 07:32 PM   #8
12field
12field Normal reputation
Re: Re: hesitation problems
HEY, DID YOU EVER FIX YOUR PROBLEMS AS I HAVE THE SAME. ANY COMMENTS YOU HAVE WOULD BE APPRECIATED. THANKS!!
12field is offline   Reply With Quote
Old 11-13-2005, 12:24 PM   #9
colinlesser
colinlesser Normal reputation
Send a message via Yahoo to colinlesser
if your engine is nocking youirnot fireing right or egine is bad, if you have a O2 code REPLACE IT
colinlesser is offline   Reply With Quote
Old 11-13-2005, 09:46 PM   #10
yautja25
Car hesitation
YES I got it fixed, check ur coil pack thats wat was wrong with mine, even tho i still beat a jetta while my coil pack was bad, no they made me change the plugs wires and the 02 sensor and the throttle sensor and it was really the coil pack so check that also.
Bookmarks
Google
Web AF
