1994 celica st204 Help
WoGZiLLa
05-03-2005, 03:29 AM
help please my knock sensor is showing open or short circut im wonder if some can help me i would like to know with the knock sensor thanks it makes my engine light come on and a result of that the car looses alot of power :(
nialusa
05-03-2005, 07:51 AM
Dont really understand your question, the knock sensor is a small but ver sensative microphone located behind cylinder 3 which listens out for pre detination of the petrol in your engine, they dont last forever and can go wrong, you`ll need either a 22mm or 24mm deep socket to remove it, and double jointed wrists. They are a common problem in Celicas and when faulty or detecting pre-detination, will run the car in a safe mode by retarding the timing.
Brian R.
05-04-2005, 06:27 PM
Check the sensor wire before you replace the sensor. The wires/connectors are easily damaged.
WoGZiLLa
05-12-2005, 06:04 AM
hi guys,
I pulled the sensor out and cleaned it , fixed the wires up a bit. Now Its been 5 days and the light hasn't come on. :)
nialusa and Brian R thanks you so much, you guys saved me au$182 thanks alot :).
nialusa
05-12-2005, 11:00 AM
No worries, expect an invoice in the post soon :) :) :)
