AC Compressor Working????drjimbo 05-02-2005, 02:40 PM I just bought a used AC compressor for my 1996 2.2L Cavalier because mine was shorted out and kept blowing fuses. Will I be able to plug the compressor in and see if it works/does not blow fuses before I do all he coolant connections or install it? In other words...can I just plug the plug into the compressor, turn the AC on, and see if the compressor works. Thanks for helping a novice. Austin8214 05-02-2005, 03:17 PM In other words...can I just plug the plug into the compressor, turn the AC on, and see if the compressor works. Thanks for helping a novice. No you can not. You will at least have to install it on the car. But you do not have to fill the system up. drjimbo 05-02-2005, 11:08 PM I was also told I would not need to install it if I just wanted to see if it would blow the fuse or not. Why would I need to install it on the car? Thanks Austin8214 05-03-2005, 02:09 PM I was also told I would not need to install it if I just wanted to see if it would blow the fuse or not. Why would I need to install it on the car? Thanks Well maybe not then but i do know this. A/C compressors have a eletrical clutch in them so i would think you would a least want to see if it worked. And it needs to be spinning to make sure it works right. smokey041369 05-04-2005, 10:59 AM Austin is correct the a/c clutch WILL NOT FUCTION without the rpm's of the engine turn the a/c compresser pully Automotive Network, Inc., Copyright ©2012
