Hot Shot Header QuestionsProZach626 04-29-2005, 04:38 PM Hey guys, i'm looking into buying a hot shot header and I have a few questions. Will I need to put header tape on it to protect it? Also, will it directly bolt on to my stock exhaust? Thanks ProZach626 04-29-2005, 04:39 PM This is for 03 spec v, btw fugiot 04-29-2005, 04:50 PM No and Yes ProZach626 05-06-2005, 05:02 PM No and Yes Will this trigger my check engine light to come on if I have it professionally installed?(have to in order to not void warrantees) ProZach626 05-12-2005, 04:26 PM Also, do I need to buy a downpipe? slideways... 05-13-2005, 03:27 AM btw you do know that the stock header has a cat in it right? and for you to comply with emissions laws in many states you need to buy an aftermarket header with a cat in it also the downpipe should be part of the header it may trigger the light if you get the header without the cat in it but im not sure it shouldnt matter whether its professionally installed or not (just dont do it if you know absolutely nothing) the only thing in the area that could cause a CE light is the O2 sensor. im not sure how sensitive they are in that car so removing one cat may or may not cause a light ProZach626 05-13-2005, 04:35 PM btw you do know that the stock header has a cat in it right? and for you to comply with emissions laws in many states you need to buy an aftermarket header with a cat in it also the downpipe should be part of the header it may trigger the light if you get the header without the cat in it but im not sure it shouldnt matter whether its professionally installed or not (just dont do it if you know absolutely nothing) the only thing in the area that could cause a CE light is the O2 sensor. im not sure how sensitive they are in that car so removing one cat may or may not cause a light I have to get a header with an aftermarked cat even if I have a second cat on the car? I thought you only had to have one cat. sybais 05-14-2005, 03:07 AM in some states you dont need any smog sybais 05-14-2005, 03:08 AM and yes and any 4 to 1 will line right up with the stock down pipe slideways... 05-17-2005, 12:33 AM in some states they dont check but in all 50 states its technically illegal to mess with ANY cat even if you have more than one sybais 05-17-2005, 12:46 AM no in AK there are no smog laws, period... he he slideways... 05-18-2005, 03:30 AM yeah in MN there are no smog laws period also but its still illegal to remove a cat in any state Automotive Network, Inc., Copyright ©2012
