1994 Jgcl Code 54stedhaz 04-29-2005, 03:18 PM What's A Code 54 And How Do I Correct It?? Dale Aeppli 04-29-2005, 06:02 PM What's A Code 54 And How Do I Correct It?? Camshaft position sensoror (distributor sync) reference circuit--no camshaft position sensor signal detected during engine rotation. Check if you have spark at coil wire if you do have spark at coil wire. Remove a plug wire test for spark. if you don't have spark at wire, the sensor inside the distributor is bad. replace sensor DALE :smokin: :naughty: dksob81 04-29-2005, 11:05 PM check the connection of the Cam Sensor. I had this happen to me when I put a new engine in. The Cam Sensor wire got caught between the Tranny and the Engine so when I bolted it up it cut the wire. Automotive Network, Inc., Copyright ©2012
