Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 04-25-2005, 07:43 AM   #1
mushhhy
mushhhy Normal reputation
97 Blazer CODE P0507
I need help finding the cause of OBD code P0507 Idle RPM higher than expected. I have replaced the Idle Control Valve and do not get the message on the highway only on short trips. I have also replaced some of the convient vacum lines. The vehicle seems to idle a bit high. can any of you more experienced than I help me with this
Thanks
mushhhy is offline   Reply With Quote
Old 04-25-2005, 12:30 PM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: 97 Blazer CODE P0507
Check for a vacuum leak causing the higher idle.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 04-26-2005, 04:55 AM   #3
mushhhy
I will check for vacum leaks today. I changed the Throttle Control Sensor yesterday it seemed that the throttle washigh when stopping I am going to drive it today to see if that helped.
Thanks I will let you know how it worked
Old 04-26-2005, 05:59 AM   #4
ricksza
ricksza's Avatar
ricksza Normal reputation
Besides the vacuum hoses, also check for a leak at the upper plenium gasket. Make sure the the hose going to the air inlet duct behind the throttle body is connected.
ricksza is offline   Reply With Quote
Old 04-26-2005, 01:33 PM   #5
mushhhy
Iwill look into the plenium an dget back thank you
Bookmarks
Google
Web AF
