Check engine light......djdelirius 04-24-2005, 09:42 AM I've got a 99 Honda Accord EX V6 and the check engine light is on. Is there anyway to turn it off without taking it into the honda shop? 19prixgt98 04-24-2005, 12:49 PM i have a 99 honda accord ex also that has the same problem, the dealerships dont know why it comes on, but they tell me to temporarily shut if off by unhooking the battery, but im gettin pissed cuz it comes right back on a few days later. I need to get it fixed permanately but i dont want to pay an assload for somthign minor! but if u want it gone for now, unhook ur battery! mpumas 04-24-2005, 01:42 PM It is coming on because the ECU is detecting a problem with one of the sensors that inputs into the ECU. You need to read the stored code/s to find why it is coming on. If there are no stored codes you have a bigger problem, a bad ECU. Disconnecting the battery will clear the stored codes but will also lockup your radio. And then you will need the radio code to get it operating again. 19prixgt98 04-24-2005, 09:01 PM it never locks up my radio! but yea, ur right he might have a bigger problem! good luck dude! 92gsr200k 04-24-2005, 09:32 PM Don't disconnect the battery each time, you'll reset everything (if radio has security code), plus it's more difficult. Just remove fuse 13, which is the Clock Backup, for about five seconds and the ECU will reset. The only thing this also resets is of course the clock. With a '99, I would say if nothing else, it probably has to do with the EGR valve. Honda really blew the big one on this generation with the EGR. I have had my '98 EX V-6 EGR replaced and port cleaned already (around 90K). Anyway, good luck finding your light problem. Automotive Network, Inc., Copyright ©2012
