Dodge Neon 1999 how to change time beltpablo1999 04-23-2005, 08:34 PM I have a Dodge Neon 1999 with 102 miles. I need to change the time belt. Is there a web site where I can go to that shows how to change the time belt? Thank you in advanced, Pablo das2123 05-25-2005, 04:41 PM Click ME (http://www.neons.org/jball/howto/timing_belt/howto.html) for a timing belt how to. Also remember to change your water pump while you are at it. TEXSRT4 05-25-2005, 09:47 PM its pretty easy. remove your passenger side tire, accesory belt, pulley, timing belt cover, and motor mounts - dont forget the middle motor mount (you will have to go in through the passenger tire well, there will be a 22mm torx head, take that out). once thats done, align timing marks on the crank. loosten the adjuster (which you should replace while your in there) remove the timing belt. 3 or 4 bolts are holding down the timing belt cover. remove that, and replace the tensioner and water pump. reassemble everything and your set. while your in there, replace your cams with something more aggressive, it will only take you an additional 30 min. expect the whole job to take you 4-6 hours. its not too tough das2123 05-26-2005, 12:28 AM while your in there, replace your cams with something more aggressive, it will only take you an additional 30 min.Are you talking about cam gears or camshafts? TEXSRT4 05-26-2005, 01:36 AM BOTH!!! hahaha, its kinda pricey, but it will be worth it! thats what i did at least das2123 05-26-2005, 09:01 AM BOTH!!! hahaha, its kinda pricey, but it will be worth it! thats what i did at leastAgreed, but if it is a SOHC, it wouldn't be as expensive. Automotive Network, Inc., Copyright ©2012
