Crank but no Start.BLAZT 04-22-2005, 10:18 PM So I was driving back home from work and when coming to a red light at about 10MPH the engine just died on me. The only thing left on was the radio. So I try to start it again and nothing. The check engine did not light up. This is for a 93 Grand Cherokee 4.0. with 145,000 miles on it. Thank you very much. Dale Aeppli 04-23-2005, 10:20 AM So I was driving back home from work and when coming to a red light at about 10MPH the engine just died on me. The only thing left on was the radio. So I try to start it again and nothing. The check engine did not light up. This is for a 93 Grand Cherokee 4.0. with 145,000 miles on it. Thank you very much. Hi, you say it would not start again. Do you mean the engine turns over but will not run. Check at the coil wire to see if you have spark. Dale jeepman600@sbcglobal.net BLAZT 04-25-2005, 07:42 PM Hi, you say it would not start again. Do you mean the engine turns over but will not run. Check at the coil wire to see if you have spark. Dale jeepman600@sbcglobal.net So I put some starting fluid in the throttle body and the jeep started and then it died on me once more. Mechanic came over yesterday and he had a( 0 PSI )for the reading on the fuel pressure. He said it could be the fuel pump that is bad or that it got stuck. He is going to drop the fuel tank to check out the pump.And I was also reading some posts here about the ( CPS ). Do you think the CPS has something to do with the jeep just shutting off by itself ? mx52nv 04-26-2005, 04:50 AM First, check ALL of your fuses. When you turn the key into the on position, no you hear the hum from the fuel pump? Check all the little things first. SteveB05 04-26-2005, 07:19 AM Well, if you get it to start with starting fluid, then it isn't the CPS. CPS would eliminate spark, not fuel. MX52NV is right...check fuses, ASD relay etc prior to droping the tank. Dale Aeppli 04-26-2005, 11:49 AM So I was driving back home from work and when coming to a red light at about 10MPH the engine just died on me. The only thing left on was the radio. So I try to start it again and nothing. The check engine did not light up. This is for a 93 Grand Cherokee 4.0. with 145,000 miles on it. Thank you very much. IF IT STARTS WITH STARTING FLUID ,YOU HAVE A FUEL PUMP PROBLEM. CHECK VOLTAGE AT TANK WITH MULTI METER. SHOULD HAVE 12 VOLTS FOR 3-4 SECONDS WHEN YOU TURN KEY ON. ALSO CHECK TO SEE IF YOU CAN HEAR THE FUEL PUMP RELAY CLICK WHEN YOU TURN THE KEY ON. HOPE THIS HELPS DALE mx52nv 04-26-2005, 02:15 PM When mine died a few weeks ago, I replaced the coil and CPS just for it to end up being one of those tiny fuses. So start will the small stuff like fuses and voltage testing. BLAZT 04-26-2005, 04:09 PM Checked all fuses and they are all good. There is no hum for the fuel pump. I'm guessing it is a fuel related problem. Thank you for pointing out the CPS for me, and eliminating the thought that the CPS could be bad. Mechanic is coming over today to drop the tank. I will post back on what the problem was. Thanks. Dale Aeppli 04-26-2005, 11:30 PM So I was driving back home from work and when coming to a red light at about 10MPH the engine just died on me. The only thing left on was the radio. So I try to start it again and nothing. The check engine did not light up. This is for a 93 Grand Cherokee 4.0. with 145,000 miles on it. Thank you very much. on the inner fender drivers side the is a white cermaic block with 2 wires. check for voltage or put a jumper wire on it see if the pump clicks dale BLAZT 04-27-2005, 01:32 AM Mechanic came over and the fuel pump is bad. Checked around for prices and 224.00 was the lowest I could find with Lifetime warranty. One more question, should I also change the Fuel Filter ? I bought the jeep in February of 2002 and I have never changed it. Thanks SteveB05 04-27-2005, 03:01 AM Wouldn't hurt. mx52nv 04-28-2005, 12:03 AM I would change the filter. There are 2 Grands at the salvage yard I could grab a fuel pump out of if you want to try that route to save money. BLAZT 04-28-2005, 12:59 AM Thanks for the offer MX. Just left the Jeep at the shop. They are going to replace the pump and put in a new filter. Everything for about $300.00. Automotive Network, Inc., Copyright ©2012
