B18B1 DOHC nonvtec to vtec?
girraffelll
04-22-2005, 01:34 AM
hi. im new. i just bought a 95 INTEGRA LS. is there any way to convert it to vtec? is it worth converting if possible?
V T E C H
04-22-2005, 02:15 AM
the LS/vtec convertion is well liked. I would say it is worth the convertion, should add some good hp.
girraffelll
04-22-2005, 11:59 AM
How much hp should it produce. i have done some research and all know for sure that needs to be replaced for that is the head solenoid and the ecu needs to be reprogrammed. is there anything else that i need to do for the conversion????
Greenblurr93
04-22-2005, 01:36 PM
yes, you need to enlarge the oil ports on the block, if youre not sure about doing this, bring it to a shop because the LS/VTEC isnt very stable unless built perfect.
girraffelll
04-22-2005, 01:58 PM
is that all that needs to be done for the conversion?
Greenblurr93
04-22-2005, 02:04 PM
well. u also need to wire your car for vtec, get a vtec ecu, enlarge the oil ports, run a couple oil line (i forget where), vtec solenoid, and i cant remember what else.
girraffelll
04-22-2005, 02:20 PM
there's more???
Greenblurr93
04-22-2005, 04:11 PM
you thought it would be easy??
CivicSpoon
04-22-2005, 04:56 PM
Man, do a google search on lsvtec. If it was reliable to just throw on the head and use the ECU, everyone would do it. A good general rule to modifying a car is to do research before you even consider doing anything; whether it be suspension, tires, bolt-ons, engine swaps, etc. So spend a few weeks or month searching on the topic and get as much info that's out there.
civickiller
04-22-2005, 07:39 PM
enlarge oil ports ?
Greenblurr93
04-22-2005, 08:15 PM
ya, i read somewhere you need to enlarge some port that oil flows throught to go to the head.. or im just sick in the head...
girraffelll
04-23-2005, 07:51 PM
so, if i was to get a gsr head and components how much horse power gain will i get? and how much horsepower if it is port and polished?
Greenblurr93
04-25-2005, 01:56 PM
AH ha! I
Greenblurr93
AH ha!
Greenblurr93
AH ha! I FOUND
Greenblurr93
AH ha! I found what i was looking for....
http://www.sportcompactcarweb.com/tech/0411scc_hybrid/
girraffelll
04-25-2005, 07:20 PM
what???
Greenblurr93
04-25-2005, 07:24 PM
click the link, its a how to on building an LS/VTEC
