BHG and not start after replaced
madflea
04-21-2005, 11:44 PM
Hi you all,
had a BHG on my cressida 7MGE lately, put in new gaskets and replaced
most of the hoses, then the engine will not start only cranks.
did the troubleshooting from page one, everything attached and good,
wires, sensors, vac hoses...
then go into fuses, fuel, wire, coil, timing,
distributor, resistances, EGR valve, and pretty much everything, STILL
NO LUCK..
it may be little low on the compression compare to the manual, but the manual was done at normal orperating temp, but will try to a leak down, after all, that is the last thing on the list.
so, need more brains out there to give some help, this is VERY FRUSTRATING thank you .
