Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Skyline / Skyline GT-R > Performance
Performance Discussion about performance modifications and issues.
Old 04-21-2005, 04:13 PM   #1
GTRVspec33
GTRVspec33 Normal reputation
R33 sputter on higher RPM
Can someone please tell me why my car would sputter when i reach 3200 rpm and higher? I have the HKS EVC and injector contoller installed. Even tho I turned it on or off, it sputters. Anyone know what is the problem? please help.
GTRVspec33 is offline   Reply With Quote
Old 04-22-2005, 03:06 AM   #2
tazdev
I'm still here
tazdev's Avatar
tazdev +250tazdev +250tazdev +250tazdev +250
Re: R33 sputter on higher RPM
checked your plugs recently?
tazdev is offline   Reply With Quote
Old 04-22-2005, 05:36 PM   #3
GTRVspec33
i did check the plugs. It seems good
Old 05-08-2005, 02:36 AM   #4
SkylineUSA
SkylineUSA's Avatar
SkylineUSA Normal reputation
Send a message via AIM to SkylineUSA
I just worked on a R33 GTR last night with the same problem. I swapped the MAFs, with the ones on my GTR and it fixed the problem, so I would check the MAFs. Take them off and give them a good spray with carb cleaner. Remeber they are very delicate. I have cleaned them with a brush and alcohol, but you have to take off the screen for that. If you do have to go that route, take the engine side screen off, not the screen on the filter side.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
SkylineUSA is offline   Reply With Quote
Old 05-08-2005, 02:38 AM   #5
SkylineUSA
SkylineUSA's Avatar
I did not read the part about the EVC, you might have an issue with that, but try the MAFs first.
Old 08-16-2005, 08:17 PM   #6
tyndago
tyndago Normal reputation
Send a message via AIM to tyndago
Bad plug, bad coil,bad maf, bad tune.
Weird at about 3200 rpms. Not normal rpm. Normally its around 2500 ish or 4500 ish.
Sean Morris
tyndago@gmail.com
tyndago is offline   Reply With Quote
Old 09-12-2005, 06:16 PM   #7
davehack
davehack Normal reputation
can someone please tell me what maf's means cause l am having the same problem with my car
davehack is offline   Reply With Quote
Old 09-13-2005, 11:57 AM   #8
tyndago
MAF is mass air flow meter. They have emotional difficulties at times.
Sean Morris
tyndago@gmail.com
Old 09-14-2005, 03:47 AM   #9
davehack
l am having same problem but it is only when l am running 12 psi not when l am running the standard boost anyone got any idea's or is it the same problem
Old 09-14-2005, 09:43 AM   #10
tyndago
You have bad plugs, or bad gas, bad tuning. Its probably putting the spark out.
What plugs are in it ?
What fuel ?
When was the last time the fuel filter was replaced ?
Have you checked base timing ?
What computer is in the car ?
Sean Morris
tyndago@gmail.com
Old 09-26-2005, 04:42 AM   #11
davehack
it is standard ecu at the moment. l use ngk plugs they are new and run bp ultimate fuel 98 octane dont know about fuel filter though but am getting it serviced next week and told them to carbon clean the air flow meter to see if that was it mr coils were a bit carbed up but just funny that l only get it on high boost and only in 2 and 3 gear
Old 09-26-2005, 12:36 PM   #12
tyndago
Which NGK plug ? What is the gap ?
You might have a coil going bad.
How much boost is high boost ?
High boost - 2nd and 3rd gear normally means its putting the spark out. It could be detonation, it could just be way too rich.
Sean Morris
tyndago@gmail.com
Old 09-26-2005, 07:24 PM   #13
davehack
12psi the gap is .8 dont think it is detonating cause there is no pinging they are iridium plugs think it might be cross fire cause coils havent been serviced will let you know. what do you think
Old 09-27-2005, 03:20 AM   #14
tyndago
Re: Re: R33 sputter on higher RPM
12 psi is not high ....it shouldnt be putting the spark out... It might be a coil or a MAF..... more likely a coil having a bad day under higher load.
But the MAFs can be trickey.
Sean Morris
tyndago@gmail.com
Bookmarks
Google
Web AF
