Noz For a ZC DOHC
rgmaniac
04-21-2005, 01:56 PM
How much will it cost? Wich one is better Wet or Dry
Skyline_BNR34
04-21-2005, 03:35 PM
If you have stock car din't even put Nitrous on it cause it will blow your motor. Wet is nitrous and gas mixed and dry is plain nitrous. The wet would be more. My opinion is have a built motor and get direct port wet injection nitrous.
rgmaniac
04-21-2005, 04:06 PM
Its aZC dohc, has apexi headers, AEM cold Air, cams what do i nedd for nos
Skyline_BNR34
04-21-2005, 04:08 PM
You need to upgrade the pushrods, cam, all the interior patrs need to be strenghened. Why do you want Nitrous Oxide???
Beyond Imagination
04-21-2005, 06:46 PM
interior parts? such as your dash and your floormat?
i've used zex dry on my stock d16 and it worked fine.
cody_vg
04-22-2005, 04:01 PM
hondas dont have pushrods my old 87 silverado did,but not my zc, they do have cam followers though. a definate thing would be to make sure your ignition is in top shape, high cylinder pressure makes it hard to create spark.also run one range colder plug. make sure as well that you dont run your engine lean pull plugs and check for detonation often, if so runa smaller jet. if you plan on running a large shot then look to upgrading to gorged pistons and maybe a stronger con rod.
Polygon
04-23-2005, 07:53 PM
Man, its a good thing someone banned this guy.
cody_vg
04-23-2005, 10:50 PM
tell me about it he gets on my nerves but hes always right
