eagle forged crankaznbmxxxer 04-21-2005, 01:39 AM i found this package for the forged eagle crank with eagle h beam rods for 799 delivered. it says its all internal balanced. is this a good crank? it seems like a pretty cheap price since the rods are about 350 so the crank is 450. anyone have any opinions? my goal is 400whp daily, 600 at track with the proper fuel and ems. aznbmxxxer 04-21-2005, 01:44 AM 1 more thing, if i get stroke it to a 2.0, is there any other kinds of mods i need to do other than a deeper oil pan? turboEKhatch 04-21-2005, 02:08 PM For starters that's more than likely just a stock stroke crank. To stroke it out to 2 litres requires a 95mm stroke, which is absolutely huge for such a small deck motor. It's not worth the hassle if it's a stock stroke, your stock crankshaft is perfectly fine. Beyond Imagination 04-21-2005, 06:52 PM do you have your motor sleeved or are you gonna be using stock sleeves? also what motor do you have? aznbmxxxer 04-21-2005, 09:59 PM i got my motor aebs sleeved with copper o rings, pauter rods, and je 81.5mm 9:1 compression. the eagle crank is stock stroke. i was just wondering if i should get the crank since the bottom end is all new parts. Automotive Network, Inc., Copyright ©2012
