door hinges and pins
Swansen
04-20-2005, 06:42 PM
its about that time and my doors are starting to fall off, so i was wondering where i could find some pins or hinges, or whatever is needed. what needs to be done to fix the problem before it gets expensive. Also i have noticed that the only way to get the pins out would be to grind off the ends. thanks for any help
Cam7
04-21-2005, 03:56 AM
The only place I could find pins and bushings is from the Dealer and believe me I tried. there about $26 for each door you probally need just the pins and bushings not the hinges. Your right you have to grind one end off or cut the pin in the middle. I found a dremmel works the best to do the grinding.You will have to take the Door off I used a couple of old tires to support it. When you install the new pins you will have to weld one end like a spot weld or pein the end to keep the new pins from comming out.
mx52nv
04-21-2005, 02:27 PM
Does the wiring harness from chassis to door disconnect easily? I need to do this soon as well.
dksob81
04-21-2005, 03:02 PM
there is a screw in the middle of the harness (I think it's a torx head not sure of the sixe) you will have to slide the boot off the door end to see it and then unscrew it and the harness will disconnect.
Swansen
04-25-2005, 05:41 PM
sweet thanks i was talking to my dad and we figured we'd have to look around, that makes things easier and thanks for the guide to.
