No Start
Olona
04-20-2005, 04:07 PM
94, 4.0, JGC will not start, getting fuel, fuses are all good, relays are all good, replaced CPS and still no start. When I crank engine, no ignition, no rpm on gauge, and no check engine light, anyone know what to check next????
dksob81
04-20-2005, 05:47 PM
sounds like cps. What brand did u use for the replacement. Borg Warner have been known to be bad 'OUT OF THE BOX'. If not BORG WARNER brand then the PCM would be the next place to check.
Check the voltage supply wire (PIN #7 White/Grey wire) going to the Cam Sensor (under distributor cap), it shoul dhave at least 8 volts when the key is in the 'ON' Position.
Olona
04-20-2005, 06:14 PM
I bought CPS at NAPA, I will try the voltage next, thanks
