Not Charging...Juzzabelle68 04-19-2005, 04:36 PM 1970 Nova SS: Ok, so a new alternator didn't help and I've check all the wiring...is there something else that I am missing...I am very new at working on cars, so I hope you all don't laugh at my question... Any suggestions would be awesome! Thanks for taking your time to answer! -Bri Juzzabelle68 04-19-2005, 04:42 PM Also, does it matter that the horn relay isn't hooked up? Since I don't have a horn...huh...this sucks! Robs71Nova 04-20-2005, 03:55 PM Does the alternator have an internal voltage regualtor? Check the upper drives side of your radiator support, right in you engine bay, for a little black box. Sounds like that could be the problem. If not, you may have gotten a faulty alternator. Bring it to any autoparts store and have it checked. Rob 72_supernova 04-23-2005, 11:40 AM You should also make sure that the wires going into your voltage requlator are in good shape. If there not making a full connection the regulator won't send enough power bake to the battery. If that is all good then you should start the car and with a volt-meter test the battery. You should be getting around 14 volts to it. Then if thats all good then it might be charging but you may have a short. To test that just disconect the negative cable and with a test light hook one end up to a groung and the other to the negative terminal. If it lights then there is a short. Just make sure the ign. is off and your int. lights arn't turned on (opened door). Good luck I just went through this on my 72 and it turned out to be my regulator wasn't plugged in all the way. Automotive Network, Inc., Copyright ©2012
