new exhaust have problem
94accordlx1
04-19-2005, 08:50 AM
my new exhaust came in yesterday. I started to bolt it on to my car and finsihed. but now i want to take out the silencer and see how it sounds, i yook out the little screw holding in the silencer but it still isnt coming out.
Whumbachumba
04-19-2005, 11:38 AM
Did you try turning the silencer to see if there was a lock in lip so it wouldn't fall out if the screw came undonw? I honestly don't know since I don't have an aftermarket exhaust, maybe if you said what type it is someone could help.
94accordlx1
04-19-2005, 12:41 PM
it is a OBX sports racing catback exhaust
mysatilac
04-19-2005, 03:29 PM
Its just stuck,
Man I had a hell of a time gettin mine out too,
What you gotta do is spray it with some penetrating oil, or WD-40, around where it meets the pipe, and grab it with some pliers, I didn't think that mine would come out at first...
you gotta PULL it, little twisting wont hurt either,
I took mine out while it was off the car though, so it was easier having my brother hold it, while it was at chest level,
came out with a bang, and hit my chest with the pliers,
Once you've got it out of there you should be able to wipe off both surfaces and get it in and out easier...
But once you've gotten it out, I doubt that you'll put it back in.
I know I didn't
94accordlx1
04-19-2005, 10:02 PM
ight thanks man i will try today. how long should i let the wd-40 set in the muffler?
vtownx
04-22-2005, 05:18 PM
had the same problem with mine, best u can do is lubricate, and pull and twist, it will come out eventually.
mysatilac
04-23-2005, 03:24 PM
since my last post I've put mine back in, it quiets "silences" it too much for me, Took it back out, its much better
But good luck with it,
BTW you should let the WD-40 sit in there a few minutes, but tap the silencer to set up vibration and allow the WD-40 to get in between the two
Penetrating oil is better, but its all about what you have
