Power doors locks n Power window help
Accord_boy619
04-18-2005, 03:07 PM
My power door locks wont work. Plus I cant control my right side wind with my master control switch but the windows work when controled at the door. PLs Help
mpumas
04-19-2005, 03:30 AM
Each window has its own fuse. Check the engine compartment fuse box. Can't help you with the power locks. My book is in California and I am in Japan. It helps to tell us what year your car is.
94hondaacc
04-19-2005, 01:36 PM
check the fuses if not it sounds like you need a master window switch. for the power locks it could be a bad motor. the power lock has a motor, get a test light and check if their is power going to the wire that is going into the motor, while you move the switch.if their is then it definitly is you power lock motor.
lorunner
04-19-2005, 06:22 PM
Ok try this, move the intermitant wiper ring to the center delay position. Then remove the #54 4o amp fuse under the hood in the engine compartment fuse box(i believe its the one that sticks up higher than the others) Leave it out for 30 sec and then reinstall it. This is to wake up the multiplex units. If it works you should be ok. If the problem comes back chances you'll need a multiplex unit
