89 Turbo weird a/c stall
ryteller
04-18-2005, 09:25 AM
Have an 89 Caravan 2.5L Turbo. It started stalling in the heat when I moved to TX. Let it sit for 15 mins, would restart and go for awhile. Got worse and worse - would stall even when not hot. Always worse when A/C is on.
I replaced the fuel pump and filter - still had problem. Got fault code 54. So replaced pickup coil, distributor cap, rotor, plugs and wires. Seemed to work fine until I turned on A/C. When the engine is above 2000 RPM, the engine starts to choke, ran normally as soon as I turned of A/C. A/C worked at idle (1000 RPM), but when I revved engine above 2000, it started to choke again. After running the A/C for awhile at idle, I turned off engine and it would not restart.
I am stumped.
vanman89
04-19-2005, 02:01 AM
Sorry, i dont really have a solution for you. But i have a quick question for you: have you ever had to replace your interior sliding door handle, because there is no information on how to install a new one anywhere!, Sorry again about your turbo, heard those were a blast to drive, but if you could would you please help me out? Id really appreciate it, thanks.
ryteller
04-19-2005, 07:35 AM
I've only had the van about 3 months. Actually, the interior sliding door handle does need to be fixed, but I haven't gotten around to looking at it or figuring out how to do it. I think mine is just loose, though.
vanman89
04-20-2005, 01:12 AM
Ok well good luck with your problem, but most of all with your door handle, there is virtually nothing out there on how to replace it...if you need to that is.
