Possibly can get a 73 charger need some info
Xenostalgia
04-15-2005, 11:52 PM
Hey guys,
I could, *possibly* have no clue at the moment, get a 73 charger w/ 318 what can i do it it and what does it run 1/4? and how much are they worth?
BleedDodge
04-16-2005, 04:08 PM
You can do anything with the right amount of money.
It's probably faster than that Camaro.
g2driver
04-17-2005, 08:45 PM
A 73 with a 440 runs in the low 15s stock.
Xenostalgia
04-18-2005, 05:31 PM
it has a 318 =P and my maro runs mid 15's stock.
Xenostalgia
What would I want to work up on it? And how much am I looking to spend in time over it? If I get it.
BleedDodge
04-18-2005, 07:50 PM
Well if your Camaro has no modifications then it's unlikely that your new Charger, if you get it, will recieve any modifications either. We aren't familiar with your spending habits though.
They're nice cars.
theFREAKnasty82
04-20-2005, 02:04 AM
Edelbrock makes a killer intake and heads for 318s that'll boost power, plus you can throw on 750 CFM carb and you will run 14s.
Xenostalgia
04-20-2005, 11:19 AM
Nice I think i'll do that carb... how much does it cost to buy?
Hmm well the v6 camaro's do run 15.5 stock =) No mods.
Spending habits: Weak.
theFREAKnasty82
04-25-2005, 04:06 AM
that carb can run up to $400
Xenostalgia
04-29-2005, 04:06 AM
Anyone in SoCal ish that would like to help out? :D If I get it.
99grandgt
06-20-2005, 02:44 AM
lets see...there was an article in april 2003 hotrod mag...the one with the paint and hotrod model on the front, that has a 318 buildup. now, with 183k mi, this little motor did some work!! it had closed chamber heads, non-magnum from a 87-91 m body (casting number was 302) if you mill these down, get the m1 aluminum intake, the 750 will do, but could be a little big. definitely get the electronic distributor from mopar. it will help a lot!! a decent cam...and that little motor, only head work, with 183K miles, made 400hp!!! all for, you guessed it, 1500 bucks...depending on machine work. but, sorry for the long post, and hope you read this, but go find that mag. you can order a back issue from hotrodmagazine.com so do it, do it now!!! AND that car will run 13's easy with stock rearend with that motor.
