Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 04-15-2005, 11:49 AM   #1
jtrevill
jtrevill's Avatar
jtrevill Normal reputation
ac/heat controls
About 2 weeks ago the recirculating button on my ac/heat controls quit working. The light doesn't even go on when it is pushed. At the same time, the AC would only blow on the floor and none of the controls would adjust it. Next time I started the Yukon the vent controls worked again, but the recirculating button was still not working.
Yesterday the AC button did the same thing - no light, and no control over the vent position. Last night after reading another thread here, I pulled the mode actuator from under the dash (drivers side of transmission hump). I opened it up and gave it a lube job. It was working fine while in my hand. After reinstalling it, I can hear it moving the vent around, but the AC is still not working. Now, the AC light is dimmly visible, but as soon as you turn the fan on, the light goes out all together.
Thoughts on this?
Thanks!
1996 GMC Yukon
jtrevill is offline   Reply With Quote
Old 04-15-2005, 05:49 PM   #2
2000CAYukon
2000CAYukon Normal reputation
Re: ac/heat controls
It's probably a bad a/c controller which means you basically have to replace the switch in the dash. I will warn you, then are not cheap. For a 96 rockauto.com shows it $95 without defog and $120 with defog.
//2000CAYukon
2000CAYukon is offline   Reply With Quote
Old 04-15-2005, 09:17 PM   #3
jtrevill
jtrevill's Avatar
Thanks - I've just ordered one. $120.00 just as you said... Hopefully that resolves the problem!
Bookmarks
Google
Web AF
