AC Bracket for my B16a SiR I swap in my Integra 95stopufool 04-14-2005, 07:21 PM ok, i have a b16a Sir I swap in my teg, i am looking for the correct ac bracket to get my air conditioning working. From what i have seen online is that the del sol ac bracket is the proper one, if anyone knows for sure please le me know, thanks in advance superbluecivicsi 04-16-2005, 10:36 PM i wonder, why would you need to use a p54 del sol ac bracket, when your not using a sohc compressor? or are you using a sohc compressor? the p54 bracket allows the sohc compressor to bolt up to a dohc motor. where is your 95 teg compressor? why not use the dohc 95 teg compressor on the original 95 teg ac bracket? stopufool 04-16-2005, 10:55 PM yeah, that is what i ended up using, i was mislead from what i was reading that everyone was posting that you need to use del sol AC bracket to get your Swap working with my ac. Turns out the P72 bracket that i have will work fine, just had to get the tension pulley installed that is why it didn't work, Gonna do an refrigerant recharge and i will be coolin, thanks Automotive Network, Inc., Copyright ©2012
