poor running '88 voyagerfielder 04-12-2005, 05:01 PM My '88 voyager [ 2.5L. F.I.] has a very rough idle, dies at stops, eats an excessive amount of fuel and has very little power. It's been like this since it was given to me last year, except it's gotten a lot worse in the past couple of weeks. The engine was rebuilt app. 20,000 miles ago. I've replaced plugs, wires, cat. converter and distance sensor. No codes come up. It does have a strong gas smell at the tailpipe when it's idling like it's running real rich :banghead: 1thunder 04-12-2005, 08:08 PM first try removing vacum line off of egr valve it is on passenger side of throttle body then disconnect battery for about 30 minutes and while disconected turn ignition key to start several times to attempt to discharge any capacitor in vehicle this will reset all adaptive memories and see if this helps fielder 04-17-2005, 07:18 PM first try removing vacum line off of egr valve it is on passenger side of throttle body then disconnect battery for about 30 minutes and while disconected turn ignition key to start several times to attempt to discharge any capacitor in vehicle this will reset all adaptive memories and see if this helps Unfortunately this didn't help at all. any ideas out there? I hate to take it to a garage, they want $75.00 and up just to look at it. :1zhelp: theFREAKnasty82 04-18-2005, 12:36 AM you could have a bad fuel pressure regulator or even a bad fuel injector. Automotive Network, Inc., Copyright ©2012
