Vibration at 55mph in 2000 Sierra
drizler
04-12-2005, 08:54 AM
305 automatic4 spd, 50K miles. does it with and before new tires. Vibrates enough to jingle change on dash at 55 or so . Nothing earlier and goes away over 60. Owner had truck since new and it only came on the last 6 - 9 months or so. Any ideas would be greatly appreciated
sherman69
04-16-2005, 10:24 AM
Hi,
One thing that has given me fits over the years with the vibration at 55 mph was the balance job.
The tire shop has a mounting system that uses a cone in the center hole.
Some wheels are not accurate enough for this to work well.
I learned to have them use an adapter that fits in the lug holes which is where the wheel mounts to the truck.
They will sometimes balk because it is a bit more work, and they might have the adapter hidden in the back.
I even had the Big O shop tell me it was broken, twice in two years.
Costco used it after I returned the same day and explained it to the manager. He did it and admitted he learned something.
Bob B
drizler
04-16-2005, 02:56 PM
Those damned cheap non greasable u joints on the drive shaft are the culpret. Rear one was self destructing.
cpljohng
01-12-2006, 07:17 PM
check carrier bearing or u joints
CREWMEMBER20X
01-19-2006, 09:15 PM
check for bent idler arm or other bent steering component. may not be bent, but could be worn. i had the same problem on a 1998 sierra
