Fuse Block
Having a problem with my fuse block. I noticed my tac and shift light were not working. So, I checked the in-line fuse and it was ok, but had no power. I had used the plug, at the bottom right side of the fuse block. I checked all the fuses and they were fine. Then I checked each for power. I find that the whole right side of the fuse block is powerless. Left side is fine.
Any suggestions on what might be wrong? Could the bulkhead conections be loose?
