Convention oil compatability with Synthetics
DRW1000
04-11-2005, 10:19 PM
I have heard that Synthetic oils and conventional oils are compatible with each other.
What does this mean?
- Can I add one litre of conventional to top up Synthetic and Vice Versa?
- Can I use 1/2 and 1/2?
- Can I swap every oil change?
- If I drain my conventional transmission fluid knowing that I will only get half out can I fill it with Synthetic? Will there be a benefit to 1/2 Synthetic and 1/2 Conventional? Will there be a problem?
curtis73
04-11-2005, 10:59 PM
completely compatible. No issues. A lot of threads have covered this so instead of us reposting the same info, you might have quicker results if you search.
DRW1000
04-13-2005, 09:02 PM
Yeah you are right...............sorry (It was late)
Anyway thanks.
curtis73
04-13-2005, 11:42 PM
:) No problem
SaabJohan
04-15-2005, 07:08 PM
Oils aren't always compatible, follow car and oil manufacturers instructions.
