98 GMC Jimmy Fuel Gaugessenay72 04-11-2005, 11:55 AM Fuel gauge isnt working, started a few weeks back, it would flip all around and finally settle in. It will show full when I fill up but never seems to go far past a half. How hard is the sending unit/pump to replace? Best aftermarket??? BlazerLT 04-11-2005, 03:28 PM Fuel gauge isnt working, started a few weeks back, it would flip all around and finally settle in. It will show full when I fill up but never seems to go far past a half. How hard is the sending unit/pump to replace? Best aftermarket??? Go with AC delco sending unit and pumps, they are tried and true. Replacement depends on how much you know about dropping tanks and such. ssenay72 04-11-2005, 04:16 PM Never dropped a gas tank but im sure its not rocket science. Ive changed a cam shalf I think I can do that. Delco units must cost a fortune however. I just want something to last 5 years or so. After that im buying a new car. BlazerLT 04-11-2005, 04:38 PM Never dropped a gas tank but im sure its not rocket science. Ive changed a cam shalf I think I can do that. Delco units must cost a fortune however. I just want something to last 5 years or so. After that im buying a new car. By genuine AC Delco if you want it to last. You can get them cheaply off of ebay brand new. johnhutchinsusa 04-12-2005, 09:01 AM Drive Tank nearly empty. Park, disconnect battery. Chock wheels, etc. Disconnect 3 lines (Pinch to release) and 2 electrical connectors from tank. spray some liquid wrench on long tank mounting bolt. Support tank with floor jack. Remove mounting bolts. Remove locking ring to replace assembly. Drive it off with NON sparking tool.(brass). Reverse back in .Hour or so project if all goes well. Good Luck John johnhutchinsusa 04-12-2005, 09:33 AM BlazerLT, Wish I had seen your post about AC Delco pumps on EBAY before I changed mine. Could have saved a bucket of $$$. Thanks for the tip. John BlazerLT 04-12-2005, 10:15 PM BlazerLT, Wish I had seen your post about AC Delco pumps on EBAY before I changed mine. Could have saved a bucket of $$$. Thanks for the tip. John You will know for next time. ;) Automotive Network, Inc., Copyright ©2012
