motor swap
my93supra
04-11-2005, 11:07 AM
i have a 93 toyota supra NA auto. i just got it and i want the engine to push 700 whp so i want to replace the NA engine with a tt engine what all do i have to do to convert it over. then eventually bigger injectors and upgrade the ecu so i can bolt a t78 single up and other basic mods.
flyinMKIV
04-12-2005, 03:51 PM
In order for you to really do it correctly, your going to have to replace the bottom end, tranny, ecu, and rear end. If you've completed that, the single turbo setup and injectors are easy after that. Your going to need a built TT tranny to take the boost from the T78. Injectors are going to be needed as well as a walboro fuel pump, maybe two to be on the safe side or if you plan to go bigger. After that plus a little misc. stuff, you should be pushing 700 easily. Any other questions, just ask away.
my93supra
04-13-2005, 04:18 PM
well thats cool. the question i have is how much work is involved it swaping out a NA engine for a tt engine./ i have the oppunity to purchase a engine with 39000 miles with starter distrubiter ac compressior turbos all manifolds exhaust, intake, ecu harness alternator power steering pump sensors mounts. for $2500 i was just wordering what all parts i'd have to swap out and everything...
flyinMKIV
04-13-2005, 06:39 PM
Your going to need the transmission definitely. The n/a tranny you have will not hold the boost. It will for a little while but it's just a matter of time, could be a week, could be 6 months. It's a gamble if you don't get a better tranny. Your also going to be missing the rear end and the gearing. You might not be satisfied with having the n/a diff but that shouldn't be a problem with durability. There is not too much work involved as long as you know what your doing. There will be some headaches with dealing with the stock vacum wiring, it's a pain in the ass as you'll find out. just try to put as much work into the motor as you can before you drop it in.
dorout
04-13-2005, 08:53 PM
I have completed the NA(2JZ-GE) to TT 6-spd(2JZ-GTE) engine swap. If anyone needs a parts list or a guid. Email me anytime at: Dorout@yahoo.com
my93supra
04-18-2005, 09:57 AM
i know it comes with a auto tranny. how big of a headache is it working on the vacum lines i wanna know all the steps before i go pulling a perfectly good engine out of a dependable car u feel me
flyinMKIV
04-18-2005, 02:11 PM
It's a pain when you don't have any help. Go to MKIV.com and they should have the vaccum diagram for it. If not, I can go outside and take a picture of the one that's underneath my hood for you.
my93supra
04-21-2005, 02:51 PM
hey what if i keep the NA engine in it and get a turbo kit. how many parts will i need to push 700whp? thanks for all ur help im checkin my options
flyinMKIV
04-21-2005, 07:15 PM
your still going to need to rebuild it with low compression pistons and better rods just in case. After that, your going to need a much better transmission like GM th400 or a upgraded TT transmission but I don't believe a TT tranny will fit or hook up. After that, then you should be able to push 700 easy. I'll look more into your trans situation for you.
my93supra
04-25-2005, 08:47 PM
how much in ur opinion do you think it will cost to do the 2jzgte swap. which would you do the swap or build up the na engine? someone online told me it cody 15k to build up the na engine and 12k to do the swap that doesnt sound right to me
macavelli04
04-26-2005, 01:55 AM
dont mean to interfere but how much money would it cost to put a turbo engine in a 5 speed n/a supra if i was paying someone, Would i still have to get a tranny and rear end?
flyinMKIV
04-26-2005, 02:17 PM
nothing is needed to do the swap other than the motor ecu and harness, but the tranny will not hold the boost for long, it was not designed to take boosted applications. It's a matter of time.
my93supra
04-26-2005, 09:18 PM
thanks i found a engine and tranny ON EBAY imma purchase when i get paid this week i appericate the help. hey i sen ur car on autotrader.com once for $8400 i was like wow jt was whne i was lookin for a supra i was gonna buy it in a heartbeat but it was spam cause the # was disconnected and alot of weird stuff
my93supra
04-29-2005, 05:05 AM
what all fuel upgrades will i need to push 700whp
