ZC Engine SpecsreXem 04-03-2002, 09:42 AM Hey... I was hoping someone here would be able to help me out. My buddy has a program called Dyno 2000 and it estimates hp and torque given info about an engine. so what I need are the technical specs for the ZC Engine. Here is a list: 1) Bore and Stroke 2) Intake and Exhaust Valve size (inches) 3) Compression Ratio 4) Induction flow (cfm) @ X inHg 5) Lifter Type 6) Cam specs @ Seat-to Seat 7) Intake Lift @ Valve (inches) 8) Exhaust Lift @ Valve (inches) 9) Lobe Center 10) Valve Overlap 11) Intake Duration 12) Exhaust Duration Thanks SiRedge 04-04-2002, 07:43 AM Hi. Don't know all of those specs for the ZC, but I can give you what I know. I've got a JDM 4th gen Civic Si... 130ps(very similar to hp) @ 6800rpm 14.7nm @ 5700rpm Displacement: 1,590cm cubed Inside diameter x distance (mm): 75.0 x 95.0 Compression ratio: 9.5 Gear ratios: Gear Manual Auto 1 3.250 2.705 2 1.944 1.500 3 1.346 1.027 4 1.033 0.780 5 0.878 - R 3.888 3.933 Gear ratios could be different depending on what you get the ZC out of. Um... Looking back I don't know if that'll help you at all, but hey, I tried Redge Automotive Network, Inc., Copyright ©2012
