Engine Warning Light On
bigwheel53
04-10-2005, 09:05 PM
I Have A 2002 Grand Caravan W/3.3 Eng.my Check Engine Lite Just Came On.all Of The Fluids Are Fine And The Van Runs Great,real Smooth.i Just Changed Over To A Sinthetic Oil Although I Doubt If Thats The Problem,or Is It A Ploy To Get You To Come To The Dealer..help....
GTP Dad
04-11-2005, 06:54 AM
Take it to Autozone and have it scanned. It could indicate a misfire in a cylinder or a bad O2 sensor. Anything could be the problem so the best way to find out what is going on is to scan it. If there is a code they will tell you what the problem is and that should enable you to correct the problem. If you need help post again and someone will provide assistance.
chigger_ns
04-11-2005, 03:12 PM
Click you key forward twice and the code should come up on the odometer. Let us know the code!
jodiz
04-11-2005, 05:32 PM
Had the same problem with my 98. Took it to Autozone, they actually lend you the machine with your Driver's License as deposit (at least here in Miami they do).
I tried the "key twice" suggestion but didn't work. My van is 2 old.
chigger_ns
04-16-2005, 06:31 AM
My van is a 2001 and it works. You must try this combo. on, off,on, off, on. Its in the haynes manual.
timd
04-16-2005, 04:17 PM
My '97 flashes a code via the Check Engine light. Blink pause blink blink means code 12 (battery disconnected recently). "55" means "End of Codes". 21 is an O2 sensor
