oil gallery plug installation
Bain
04-10-2005, 03:13 AM
I was wandering first is it oil gallery or oil galley plugs I have seen it both ways and when I search for info on them I get matches from either spelling. Anyway I was wandering what the proper procedure for installing them are? I have seen one site that said to turn them three full turns only. I have seen one that said to turn them until they are flush with the block. I haven't tested to see if these are in turn the same amount but I don't want to strip anything trying to find out so if any of you have a sure fire method please share it with me. Thanks
MagicRat
04-10-2005, 10:04 AM
It's 'gallery'
These are pipe threads, so as you screw them in they will get progressively tighter. This is because pipe threads are designed with a slight 'interference fit' to help sealing. Screw them in until they are reasonably firm. Use a sealer on the threads. You can use teflon tape of silicone but I prefer plumbers threaded joint compound (like a paste) used for threaded iron pipe.
